[gdal-dev] gdal.h: No such file or directory
Riki Tiki
mongoose_riki at mail.ru
Mon Oct 12 17:21:16 EDT 2009
I am using bloodshed dev-C++...
I have written only this
#include <stdio.h>
#include <stdlib.h>
#include <gdal.h>
int main(int argc, char *argv[])
system("PAUSE");
return 0;
Before compiling it i have installed the FWTools2.4.5,
all header files are located in
C:\Program Files\FWTools2.4.5\include
Now before compiling and running above program
i have added to the
Tools->Compiler Options->Directories->Libraries
the above path of the fwtools' include folder...
when i compile and run it... it says the following:
C:\...\main.c gdal.h: No such file or directory.
C:\...\Makefile.win [Build Error] [main.o] Error 1
can you help me to solve the problem?
thanks a lot in advance.
