[gdal-dev] how to test the creation and deletion capability of
ogr?
Even Rouault
even.rouault at mines-paris.org
Thu Oct 15 13:50:33 EDT 2009
Selon Chaitanya kumar CH <chaitanya.ch at gmail.com>:
Atubar
As Chaintanya says and the doc recommands it, you must use the macro and not
string values directly. For one good reason : #define ODrCCreateDataSource
expands to "CreateDataSource"... So "ODrCCreateDataSource" is an invalid input
for OGRSFDriver::TestCapability().
You're also mentionning functions that take strings as arguments but you don't
know which values are valid. Could you be more explicit about which functions ?
Generally the doc should make it clear about the expected meaning / accepted
values. But things can always be improved ;-)
Even
> atubar,
> Here is a sample.
> http://trac.osgeo.org/gdal/browser/trunk/gdal/apps/ogr2ogr.cpp#L401
> The preferred #define macro forms are used here. (
> http://www.gdal.org/ogr/classOGRSFDriver.html#6c37cb7552902cd27cd6d4b904d7c744
> As per your problem, perhaps the drivers you tested did indeed not support
> creation and deletion. Which drivers were they?
> 2009/10/15 atubar <atubar at 126.com>
> > Hi,
> > I want to take a test about the capability of creation and deletion for
> > all supported formats of ogr .
> > The code like below, The parameter "const char" are copied from api doc.
> > But all flag return a value of 0, why ?
> > int flag;
> > flag=poDriver->TestCapability("ODrCCreateDataSource");
> > if(flag==TRUE)
> > cout<<endl<<" --Supported Creation. "<<endl;
> > flag=poDriver->TestCapability("ODrCDeleteDataSource");
> > if(flag==TRUE)
> > cout<<endl<<" --Supported Deletion. "<<endl;
> > Many funcions need const char * params, is there a list of these values ?
> ç½æåå
å¹´èäº¿èµæé
ï¼3Då½éµç½æ¸¸ã天ä¸è´°ãï¼å
è´¹é¢å
ç<http://allyes.nie.163.com/main/adfclick?db=afanie&bid=1256,612,23&cid=146,4,1&sid=1353&show=ignore&url=http://tx2.163.com/fab.html>
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
