[gdal-dev] Parallel Processing
Sean Hills
mseanhills at villagis.com
Fri Oct 16 15:18:38 EDT 2009
Hello list,
I am trying to find information about using fwtools (specifically the
gdal_retile tool) in a cluster computing environment running beowulf or
condor or, utilizing GPU processing with the CUDA programming tools for the
Tesla or other stream processing video card. If you are aware of any
helpful resources, I would appreciate a push in the right direction.
Thanks
Sean Hills
VillaGIS, Inc.
www.villagis.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091016/f72d01b9/attachment.html
