[gdal-dev] opening an S-57 dataset directory
Frank Warmerdam
warmerdam at pobox.com
Sun Oct 18 12:47:08 EDT 2009
gdal user wrote:
> I think there is a bit more there than that. The driver (at least the
> older version we use) will also deal with the multi-level style Primar
> format systems.
> Frank Warmerdam wrote:
>> The driver will only find update files if they are in the same directory
>> as the .000 file, have names like .001, etc and a shared basename.
>> Best regards,
Mr. Xonx,
Can you give more information on this? Do you mean specifically with regard
to finding update files, or with regard to supporting directories of S-57
files?
What version are you using? How are the Primar datasets organized?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
