[gdal-dev] jp2kak setting error on Windows
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Mon Oct 19 16:38:13 EDT 2009
hi Frank and list,
I copied all the Kakadu *.h files that jp2kakdataset.cpp refers to its
local directory.
Now the "cannot find jp2_local.h" error is gone and I got the error:
C:\build2\gdal\frmts>cd jp2kak   && nmake /nologo /f makefile.vc   && cd
        cl /nologo /MD /EHsc /Ox /W3 /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_N
O_DEPRECATE /DNDEBUG -I..\..\port -I..\..\ogr -I..\..\gcore  -I..\..\alg
-I..\..
\ogr\ogrsf_frmts -IC:\build2\kakadu KAKLIB =
C:\build2\kakadu\lib_x86\kdu_v62
R.lib /DKDU_PENTIUM_MSVC /GX -DOGR_ENABLED  /c jp2kakdataset.cpp
copy C:\build2\kakadu KAKLIB =
C:\build2\kakadu\lib_x86\kdu_v62R.lib\*.obj ..\o
The syntax of the command is incorrect.
NMAKE : fatal error U1077: 'copy' : return code '0x1'
My Kakadu parameters in gdal nmake.opt is wrong. Would someone help?
thanks,
Shawn
PS
The posts that I sent out don't show on my Gdal mails. Would someone
please confirm that you can see this?
_____________________________________________
Sent: Monday, October 19, 2009 4:10 PM
To: gdal-dev at lists.osgeo.org
Subject: jp2kak include error on Windows
hi list,
I have Kakadu 6.21 (non-commercial license) on C:\build2\kakadu\v6_2_1\
Kakadu libraries are generated using coresys_2008.sln and
kdu_managed_2008.sln
I am using the followings for jp2kak
Compiler: MS VS 9.0 (2008)
Gdal: gdal-svn-stable-2009.08.03
http://trac.osgeo.org/gdal/wiki/JP2KAK states:
	In GDAL/OGR trunk (1.7dev) I have substantially updated the
makefile.vc and nmake.opt entries for Kakadu support. Now it should be
sufficient to update the nmake.opt entries appropriately for your local
tree:
	# Uncommment if you have Kakadu 6.0 or newer
	KAKDIR = 	\warmerda\pkg\kakadu-6.2.1
	KAKLIB =	$(KAKDIR)\lib_x86\kdu_v62R.lib
	KAKSRC =	$(KAKDIR)\v6_2_1-00256N
I have checked nmake.opt from the latest Gdal 1.6.2 and overnight stable
release, none of them has the above 3 lines. They all have
"# Uncommment if you have Kakadu 4.0 or newer" and one more line:
"#KAKDIR =	D:\warmerda\jp2\kakadu"
I tried to imitate by adding:
KAKDIR =	C:\build2\kakadu\v6_2_1
KAKLIB =	C:\build2\kakadu\lib_x86\kdu_v62R.lib
KAKSRC =	C:\build2\kakadu\v6_2_1
but getting error at
/D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG -I..\..\port -I..\..\ogr
-I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts
-IC:\build2\kakadu\v6_2_1\managed\all_includes /DKDU_PENTIUM_MS
cl : Command line warning D9035 : option 'GX' has been deprecated and
will be removed in a future release
cl : Command line warning D9036 : use 'EHsc' instead of 'GX'
jp2kakdataset.cpp
jp2kakdataset.cpp(34) : fatal error C1083: Cannot open include file:
'jp2_local.h': No such file or directory
NMAKE : fatal error U1077: '"c:\Program Files\Microsoft Visual Studio
9.0\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
The compiler cannot find the 'jp2_local.h' which is in
C:\build2\kakadu\v6_2_1\managed\all_includes.
I then changed KAKDIR =	C:\build2\kakadu\v6_2_1\managed\all_includes,
and still got the same error
What are the correct Gdal jp2kak settings on Windows?  Is there an
KAK_INCLUDE?
thanks,
Shawn
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091019/c693382a/attachment.html
