[gdal-dev] JP2KAK updated jp2kakdataset.cpp eliminates 15 gcc warnings
Greg Coats gregcoats at mac.com
Tue Oct 20 22:29:01 EDT 2009
Compiling GDAL version 1.6.2's Kakadu based JPEG2000 support in frmts/
jp2kak/jp2kakdataset.cpp with gcc version 4.2.1 yields from the "Set
some user-overridable parameters." section the following warning 15
times jp2kakdataset.cpp:2472: warning: deprecated conversion from
string constant to ‘char*’. A small syntax change eliminates these
warnings. You can download an updated jp2kakdataset.cpp that does not
yield these compiler warnings from http://homepage.mac.com/gregcoats/jp2.html
Greg
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091020/f30aeec2/attachment.html
