[gdal-dev] GDAL scripting with Python 2.5 (on windows)
Aleksey Naumov
anaumov at gmail.com
Wed Oct 21 13:06:08 EDT 2009
Ivan,
Thank you, this works. I must have overlooked the gdal-python bindings
package in the Advanced settings on my last try.
Comparing to FWTools, I get a sense that the OSGeo4W GDAL/Python bundle is
pretty complete. At least it has all the usual GDAL utility programs and
python scripts.
One thing I am currently missing in OSGeo4W GDAL is support for ECW and
MrSID -- is it available? I've installed the gdal-ecw and gdal-mrsid
packages, but it seems I am missing the DLLs. E.g. when I try "gdalinfo
--formats" I get complaints:
ERROR 1: Can't load requested DLL:
C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_ECW_JP2ECW.dll
126: The specified module could not be found.
C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_MrSID.dll
Have tried this with both gdal-* and gdal16-* packages. And remembered to
run gdal16.bat to activate the GDAL 1.6 environment. However, can't get ECW
and MrSID support.
I suspect this is due to licensing issues. Do I need to install support for
these formats separately?
Thank you,
Aleksey
On Mon, Oct 19, 2009 at 10:49 PM, Ivan <ivan.lucena at pmldnet.com> wrote:
> Aleksey
> Installing GDAL + Python 2.5 + "GDAL Python bindings" through the advanced
> settings usually works pretty easy.
> And the you should be able to launch the OSGeo4W Shell and access it,
> example:
> C:\OSGeo4W> Python
> >>> from osgeo import gdal
> >>> gdal.VersionInfo()
> '1520'
> Notice that OSGeo4W install its own Python 2.5 distribution. So if you have
> a previous installation of Python 2.5, that is not going to access the GDAL
> bindings.
> Regards,
> Ivan
> Aleksey Naumov wrote:
>> Dear GDAL users,
>> My apologies if this is a repeated question, I searched the mail acrhives
>> and found a few discussions on this subject, but no resolution, AFAIK. I may
>> have overlooked a good thread, would appreciate a link.
>> My problem is being able to do scripting with GDAL using Python 2.5 (this
>> version is important because of integration/compatibility with a number of
>> other packages, mainly IPython), and I need to be able to do it on Windows.
>> I attempted a few approaches, but could not figure out how to get all the
>> pieces to work together:
>> - FWTools 2.4.5; however it comes with Python 2.3, an older version
>> - OSGEO4W
>> - Went through the Express setup and chose GDAL (+ GRASS, QGIS).It
>> installed Python 2.5.2; however on "import gdal" I get error "No module
>> named gdal".
>> - I looked through the Advanced setup and tried it a few times with
>> various options related to GDAL, however was not able to get it to work. Are
>> there specific options that should be enabled to make GDAL/Python scripting
>> possible in OSGEO4W?
>> - Tried to "easy_install gdal", this finds GDAL 1.6.1 and puts a
>> suitable *.egg into C:\Python25\Lib\site-packages. But when I try to "import
>> gdal" I get the error stating that gdal16.dll was not found.
>> Is there a way to achieve this on Windows? Do I need to compile GDAL on my
>> windows box; if so, should I be using Cygwin or try to download MS VC++?
>> Thank you
>> Aleksey
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091021/e477c6d7/attachment.html
