Re: [gdal-dev] Building from the trunk, error related to WKTRASTER
Ivan
ivan.lucena at pmldnet.com
Wed Oct 21 14:01:06 EDT 2009
D'accord. That driver should be optional.
> -------Original Message-------
> From: Even Rouault <even.rouault at mines-paris.org>
> Subject: Re: [gdal-dev] Building from the trunk, error realted to WKTRASTER
> Sent: Oct 21 '09 11:48
> Selon Ivan <ivan.lucena at pmldnet.com>:
> Yes, I had seen that too and fixed it a few days ago but forgot to commit it
> apparently. Done in r17860 by testing the availability of PG headers.
> > I tried to build from GDAL trunk and got an dependency error on wktraster
> > driver.
> > After removing it from frmts/makefile.vc the build and install worked all
> > right.
> > --- makefile.vc (revision 17859)
> > +++ makefile.vc (working copy)
> > @@ -12,7 +12,7 @@
> > -DFRMT_jaxapalsar -DFRMT_ers -DFRMT_ingr -DFRMT_dimap \
> > -DFRMT_gff -DFRMT_terragen -DFRMT_gsg -DFRMT_cosar -DFRMT_pds \
> > -DFRMT_adrg -DFRMT_coasp -DFRMT_tsx -DFRMT_blx -DFRMT_til \
> > - -DFRMT_r -DFRMT_wktraster
> > + -DFRMT_r
> > Regards.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
