Re: [gdal-dev] GDAL scripting with Python 2.5 (on windows)
Ivan
ivan.lucena at pmldnet.com
Wed Oct 21 14:06:24 EDT 2009
Frank,
By the way, about this bold text *This DSDK is not free software, you should contact LizardTech to obtain it (see
link at end of this page).* on http://www.gdal.org/frmt_mrsid.html Is that current? I believe that LizardTech
changed the terms of that DSDK license. Did they?
Regards,
Ivan
> -------Original Message-------
> From: Frank Warmerdam <warmerdam at pobox.com>
> Subject: Re: [gdal-dev] GDAL scripting with Python 2.5 (on windows)
> Sent: Oct 21 '09 12:56
> Ivan wrote:
> > Aleksey,
> >> Thank you, this works. I must have overlooked the gdal-python bindings
> >> package in the Advanced settings on my last try.
> > Welcome.
> >> One thing I am currently missing in OSGeo4W GDAL is support for ECW and
> >> MrSID -- is it available? I've installed the gdal-ecw and gdal-mrsid
> >> packages, but it seems I am missing the DLLs. E.g. when I try "gdalinfo
> >> --formats" I get complaints:
> >> ERROR 1: Can't load requested DLL:
> >> C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_ECW_JP2ECW.dll
> >> 126: The specified module could not be found.
> >> C:\OSGeo4W\apps\gdal-16\bin\gdalplugins\gdal_MrSID.dll
> >> Have tried this with both gdal-* and gdal16-* packages. And remembered to
> >> run gdal16.bat to activate the GDAL 1.6 environment. However, can't get
> >> ECW and MrSID support.
> >> I suspect this is due to licensing issues. Do I need to install support
> >> for these formats separately?
> > Yes, you need to get the SDKs from Erdas and Lizartech.
> > See the GDAL supported format list for information:
> > http://www.gdal.org/formats_list.html
> Aleksey,
> I would add that the OSGeo4W package pages for these packages have
> additional details:
> http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-mrsid
> http://trac.osgeo.org/osgeo4w/wiki/pkg-gdal-ecw
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
