[gdal-dev] HFA CreateCopy() not setting no data value
Kyle Shannon ksshannon at gmail.com
Wed Oct 21 15:54:02 EDT 2009
Hello All,
I am using python bindings to read a srtm data and create new hfa files.  If
I do not explicitly set the no data value for the band, it is not copied
over to the new dataset.  I am getting .aux files with the NoDataValue tag,
but the value is not copied to the dataset itself.  I checked the code for
CreateCopy() and did not find any call to SetNoDataValue().  Is there some
reason why the HFA driver doesn't do this?
Regards,
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)646-6577
kshannon at fs.fed.us
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091021/75aed5df/attachment.html
