[gdal-dev] driver paths - either/or
William Kyngesburye
woklist at kyngchaos.com
Wed Oct 28 14:58:56 EDT 2009
On Oct 28, 2009, at 1:25 PM, Frank Warmerdam wrote:
> William Kyngesburye wrote:
>> I just noticed that when setting GDAL_DRIVER_PATH in the
>> environment, it overrides the paths configured into GDAL, instead
>> of adding to those paths. Was this intentional? Any way to tell
>> GDAL to *add* GDAL_DRIVER_PATH to the configured paths?
>> I want to override the installed GRASS plugin when starting up
>> GRASS to point to a version compatible with the GRASS being started.
>> ie:
>> installed plugin: gdal_ & ogr_GRASS v6.4
>> also installed as a plugin: gdal_ECW_JP2ECW
>> GDAL_DRIVER_PATH=/path/to/GRASS-6.5/lib/gdalplugins (gdal_ &
>> ogr_GRASS v6.5)
>> So, the v6.5 plugin is loaded, but now I don't have my ECW plugin.
> William,
> There is no way to ask that GDAL_DRIVER_PATH be added to the default
> path, but it can hold a list of directories so you can supply the new
> directory and the old directories.
> eg.
> GDAL_DRIVER_PATH=path/to/GRASS-6.5/lib/gdalplugins:/path/to/normal/
> gdal/plugins
I kinda figured I'd have to do something like that. But then the
problem is discovering the configured paths. Since I'm dealing with
my own distributions, I could assume what those paths are...
thanks anyways
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
