[gdal-dev] OGR VRT Schema Support
    Frank Warmerdam
    warmerdam at pobox.com
    Fri Oct 30 08:25:33 EDT 2009
Alexandre Gacon wrote:
> Hi Franck,
> Does the field definitions will replace the need to define a csvt file
> for defining the types of a CSV file read with the VRT format to get
> geographical coordinates ?
Alexandre,
If you are using a VRT front end to a csv, then yes, the VRT could be
used to provide detailed field type, and width information instead of
using a .csvt.
Best regards,
