[Gdal-dev] shifting in modis data reprojection
    agnes123
    agnesyipck at gmail.com
    Tue Sep  1 03:37:53 EDT 2009
I am now dealing with the reprojection of modis 500m data to WGS84 by
gdalwarp.
I defined the original and target projection parameters of modis data as
srs='+proj=sinu +R=6371007.181 +nadgrids=@null +wktext'
trs='+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
and found that the result still had y direction shifting.
Why would these happen?
Moreover,I merged a series of hdf files (by gdal_merge.py) and then
reprojected it. I noticed that some kind of shifting existed when compared
with the individual reprojected hdf file.
Did I do something wrong?
Regards,
Agnes
View this message in context: http://n2.nabble.com/shifting-in-modis-data-reprojection-tp3558886p3558886.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
