[Gdal-dev] c# corner coordinates in latitude / longitude?
coastalrocket
andy at planetnomad.com
Tue Sep 1 10:49:16 EDT 2009
Hello all,
I'm very much new to GDAL and have been for the last couple of days
following the c# implementation examples. I have noticed that the corner
coordinates output of gdalinfo for my image will contain the projected
coordinate values followed by the unprojected latitude / longitude values. I
have not been able to find a similar technique in the c# examples or through
the class descriptions. I suppose I can take the projection information and
turn to Proj4 to convert the projected coordinates but since gdalinfo in
command line form is spitting out these values I thought they would be
available through the c# gdal libraries. Is this the case or am i missing
something?
Many thanks,
Andrew
In the example GDALInfo.cs
Console.WriteLine( "Corner Coordinates:" );
Console.WriteLine(" Upper Left (" + GDALInfoGetPosition( ds,
0.0, 0.0) + ")");
Console.WriteLine(" Lower Left (" + GDALInfoGetPosition( ds,
0.0, ds.RasterYSize) + ")");
Console.WriteLine(" Upper Right (" + GDALInfoGetPosition( ds,
ds.RasterXSize, 0.0) + ")");
Console.WriteLine(" Lower Right (" + GDALInfoGetPosition( ds,
ds.RasterXSize, ds.RasterYSize) + ")");
Console.WriteLine(" Center (" + GDALInfoGetPosition( ds,
ds.RasterXSize / 2, ds.RasterYSize / 2) + ")");
Console.WriteLine("");
and..
private static string GDALInfoGetPosition(Dataset ds, double x, double y)
double[] adfGeoTransform = new double[6];
double dfGeoX, dfGeoY;
ds.GetGeoTransform(adfGeoTransform);
dfGeoX = adfGeoTransform[0] + adfGeoTransform[1] * x +
adfGeoTransform[2] * y;
dfGeoY = adfGeoTransform[3] + adfGeoTransform[4] * x +
adfGeoTransform[5] * y;
return dfGeoX.ToString() + ", " + dfGeoY.ToString();
Example of gdalinfo..
Corner Coordinates:
Upper Left ( 228000.000, 22200.000) ( 2d 2'53.37"E, 0d12'2.77"N)
Lower Left ( 228000.000, 22000.000) ( 2d 2'53.37"E, 0d11'56.26"N)
Upper Right ( 228200.000, 22200.000) ( 2d 2'59.84"E, 0d12'2.77"N)
Lower Right ( 228200.000, 22000.000) ( 2d 2'59.84"E, 0d11'56.26"N)
Center ( 228100.000, 22100.000) ( 2d 2'56.61"E, 0d11'59.51"N)
Apologies if this post appears twice. My first was rejected through me not
subscribing before sending.
View this message in context: http://n2.nabble.com/c-corner-coordinates-in-latitude-longitude-tp3560997p3560997.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
