[gdal-dev] is Antarctic Polar Stereographic (EPSG:3031) properly
handled by GDAL?
Even Rouault
even.rouault at mines-paris.org
Tue Sep 1 14:45:25 EDT 2009
Daniele,
I suggest you file a Trac ticket on this with the following info. From a first
review, it seems that libgeotiff doesn't deal with the EPSG projection method
9829 used by EPSG:3031, aka "Polar_Stereographic (variant B)" according to
http://javadoc.geotools.fr/2.4/org/geotools/referencing/operation/projection/Stereographic.html.
I'm not sure if OGRSpatialReference is ready for that variant B of Polar
Stereographic. The page mentions a "standard_parallel_1" parameter that testepsg
doesn't show.
I've tried the following patch (assuming, maybe wrongly, that projection 9829
could be used an alias of 9810) on an image generated by "gdal_translate -a_srs
EPSG:3031 src.tif dst.tif" and it helps a bit. The projection is retrieved but
the parameters are all 0, so there are maybe other bits missings or it might
also be a problem in the write part of libgeotiff. If it comes from a non-GDAL
based software, attaching your geotiff image () or a link to it might also help.
$ svn diff frmts/gtiff/libgeotiff/
Index: frmts/gtiff/libgeotiff/geo_normalize.c
--- frmts/gtiff/libgeotiff/geo_normalize.c (révision 17587)
+++ frmts/gtiff/libgeotiff/geo_normalize.c (copie de travail)
@@ -998,6 +998,7 @@
return( CT_ObliqueStereographic );
case 9810:
+ case 9829:
return( CT_PolarStereographic );
case 9811:
Needs a projection expert to sort that out I think.
Best regards,
Even
Selon Daniele Romagnoli <daniele.romagnoli at geo-solutions.it>:
> Hi list,
> I'm working on a geotiff image which is projected as EPSG:3031 (Antarctic
> Polar Stereographic).
> When running the last fwtools's gdalinfo, I get the following:
> Coordinate System is:
> PROJCS["WGS 84 / Antarctic Polar Stereographic",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.2572235630016,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3031"]]
> It seems that the projection part is missing (taking a look here:
> http://spatialreference.org/ref/epsg/3031/prettywkt/)
> Also trying to run a gdal_translate specifying -a_srs EPSG:3031 the
> projection definition of the newly created tiff is still missing.
> Does anyone has additional information on that topic?
> Thank you very much.
> Regards,
> Daniele
> Eng. Daniele Romagnoli
> Software Engineer
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax: +39 0584983027
> mob: +39 328 0559267
> http://www.geo-solutions.it
