[gdal-dev] Missing msvcr80.dll ?
Martin Chapman
chapmanm at pixia.com
Thu Sep 3 16:27:37 EDT 2009
Harsh,
Hey, good point and on another note, recently Microsoft released a Visual
Studio update that deploys an even newer version of the CRT that fixes a
security fix. Problem is that if you have Automatic Updates turned on and
you don't know that you got this update you can make the mistake of
recompiling your project and setup application without including the merge
module dependency for the new CRT in your setup program. When you deploy to
a machine that didn't get this update you will get a nasty error that your
app can't start because of a missing DLL or missing side by side dependency.
Moral of the story, if GDAL use to work and it doesn't anymore all of the
sudden check your manifest and make sure you know what CRT or CRT's your
application needs to redistribute.
Martin
-----Original Message-----
From: Harsh Govind [mailto:harsh.govind at spadac.com]
Sent: Thursday, September 03, 2009 2:21 PM
To: Martin Chapman; 'Martin Hvidberg'; gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Missing msvcr80.dll ?
And unlike previous versions (msvcrt71) you cannot copy over 8.0 versions
dlls from somewhere to your application directory in order to make it work.
The solution per Martin's suggestion is to install vcredist.exe.
Regards,
Harsh Govind
SPADAC Inc.
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Martin Chapman
Sent: Thursday, September 03, 2009 4:00 PM
To: 'Martin Hvidberg'; gdal-dev at lists.osgeo.org
Martin,
Sounds like that copy of GDAL you have has a manifest dependency on that
version of the C runtime. You can download the vcredist.exe for the 8.0
version of the CRT from Microsoft and install it on that computer or make
your own by including the merge module for that CRT in a custom setup
program.
Best regards,
Martin
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Martin Hvidberg
Sent: Thursday, September 03, 2009 1:57 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Missing msvcr80.dll ?
Dear Group
Thanks for GDAL
I am running a script in Python, using GDAL.
Would like to run it on another (faster) computer.
Installed Python and GDAL
When I run the program it asks for a MSVCR80.dll file
Cant find it anywhere on the computer
Tried to copy it from the old computer, but it won't accept to load that.
What the h... is MSCVR80 and how do I get it onto my computer ???
Best Regards
Martin Hvidberg
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
