[gdal-dev] raster image convertion(tiff)
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Sep 10 11:43:28 EDT 2009
Dipa,
Can you give some more info on what you want to do and the programming
language you intend to use?
If it is just conversion from tiff to another you may want to consider using
gdal_translate utility.
Please look at http://www.remotesensing.org/libtiff/ and
http://www.remotesensing.org/libtiff/build.html#PC for sourcecode and
building instructions respectively.
On Thu, Sep 10, 2009 at 11:42 AM, DIPA BISWAS <dpbiswas at gmail.com> wrote:
> Sir, Please give the appropriate code using visual studio in .tiff
> raster image conversion.
> dipa
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090910/96339fa4/attachment.html
