[gdal-dev] Shortening execution time of Python script
Roger André
randre at gmail.com
Sat Sep 19 01:16:43 EDT 2009
So the problem is that ArcGIS Server is expecting the data to be ready
(unzipped), but due to the large size of the data set, the unzip has not
finished?
Roger
On Wed, Sep 9, 2009 at 3:54 AM, David Shi <davidgshi at yahoo.co.uk> wrote:
> I have a Python script that automatically downloads zip files containing
> large datasets from another server and then unzips the files to further
> process the data.
> It has been used as a geoprocessor of ArcGIS Server.
> The script works fine when two datasets each has several kilobytes size,
> but the script stops half way when datasets were about 11,000KBytes.
> I think that the execution time is too long and ArcGIS Server just simply
> killed the process.
> What actions can I try to reduce the execution time?
> ArcGIS Server only works on the basis of 32 bits and I was told that the
> maximum memory it can utilise is 4 MBytes.
> I should be grateful if someone can make suggestions/recommendations.
> Sincerely,
> David
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090918/228bb129/attachment.html
