[gdal-dev] Re: gdal_rasterize with a NetCDF file?
Hermann Peifer peifer at gmx.eu
Mon Sep 21 14:43:10 EDT 2009
The driver doesn't support updating netCDF files. gdalinfo --formats says:
  GTiff (rw+): GeoTIFF
  netCDF (rw): Network Common Data Format
The "+" indicates update support, which is obviously missing for netCDF format.
Hermann
-------- Original Message  --------
Subject: Re:gdal_rasterize with a NetCDF file?
To:
Date: 21/09/2009 20:37
> Evan,
> Thanks, that seems to be getting me in the right direction: I'm no
> longer getting the segfault error, or "ERROR 5" at all.
> However, now it's giving me a different error.  The first line has the:
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> message, like I would expect from when I do this with GeoTIFF files.
> But following that I am getting a whole bunch of this error, repeated
> many times:
> ERROR 6: WriteBlock() not supported for this dataset.
> Doing a search online, I'm getting the impression that this might mean
> that gdal_rasterize doesn't support writing to a NetCDF file?  Is this
> correct, or does the problem lie elsewhere with my calling of the utility.
> Here's the command line I'm using now:
> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize -i -burn 0 -l
> "OGRGeoJSON" dummy.json
> 'NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement'
> Thanks again for the help!
> Scott
> Even Rouault wrote:
>> Selon Scott Lewis <scott.lewis at nsidc.org>:
>> Scott,
>> Anytime you want to access to a subdataset with a gdal utility, you must use the
>> value of the relevant SUBDATASET_xxx_NAME metadata item, in that instance
>> The segmentation fault however wasn't expected, so I commited fixes per ticket
>> http://trac.osgeo.org/gdal/ticket/3146 to error out more nicely.
>> Best regards
>>> Hi,
>>> I'm still fairly new at using GDAL, but I am having trouble burning a
>>> vector image onto a NetCDF file.  I've had success with using
>>> gdal_rasterize to burn a vector onto a GeoTIFF file, but when I try to
>>> burn the same vector onto a NetCDF file, I get an error.
>>> Based on the error, I'm suspecting it's because it doesn't know how to
>>> find the right "band" in the NetCDF File (I want the
>>> "Albedo_with_1400_Local_Time_of_Measurement" subdataset), but although
>>> I've looked at the documentation, I'm not sure how to specify this to
>>> gdal_rasterize.
>>> Any help would be much appreciated!  Below is the info.
>>> Here is the command I am trying to run:
>>> "OGRGeoJSON" dummy.json Albedo.nc
>>> And the error I get:
>>> ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
>>> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize: line 9: 26950
>>> Segmentation fault      $FWTOOLS_HOME/bin/`basename $TARGET` "$@"
>>> Here is the gdalinfo for Albedo.nc:
>>> Driver: netCDF/Network Common Data Format
>>> Files: Albedo.nc
>>> Size is 512, 512
>>> Coordinate System is `'
>>> Metadata:
>>>   NC_GLOBAL#Conventions=CF-1.4
>>>   NC_GLOBAL#institution=National Snow & Ice Data Center, Boulder, CO
>>>   NC_GLOBAL#title=AVHRR Polar Pathfinder Twice-Daily 5 km EASE-Grid
>>> Composites Albedo
>>>   NC_GLOBAL#source=See the title and references for this information
>>>   NC_GLOBAL#comment=Not set at this time
>>>   NC_GLOBAL#references=Documentation available at:
>>> http://nsidc.org/data/docs/daac/nsidc0066_avhrr_5km.gd.html
>>>   NC_GLOBAL#history=Mon, 21 Sep 2009 09:31:24: File created.
>>> Subdatasets:
>> SUBDATASET_1_NAME=NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement
>>>   SUBDATASET_1_DESC=[1x244x242]
>>> Albedo_with_1400_Local_Time_of_Measurement (8-bit integer)
>>>   SUBDATASET_2_NAME=NETCDF:"Albedo.nc":latitude
>>>   SUBDATASET_2_DESC=[244x242] latitude (64-bit floating-point)
>>>   SUBDATASET_3_NAME=NETCDF:"Albedo.nc":longitude
>>>   SUBDATASET_3_DESC=[244x242] longitude (64-bit floating-point)
>>> Corner Coordinates:
>>> Upper Left  (    0.0,    0.0)
>>> Lower Left  (    0.0,  512.0)
>>> Upper Right (  512.0,    0.0)
>>> Lower Right (  512.0,  512.0)
>>> Center      (  256.0,  256.0)
>>> And for completeness, the dummy.json file (it's basically a triangle):
>>>     "type": "FeatureCollection",
>>>     "features": [{
>>>         "type": "Feature",
>>>         "properties": { "BASIN_ID": 1.000000, "AREA_SQKM": 1739.016470 },
>>>         "geometry": {
>>>             "type": "Polygon",
>>>             "coordinates": [ [
>>>                 [ -2000000, -2500000 ],
>>>                 [ -2500000, -1400000 ],
>>>                 [ -1500000, -1400000 ],
>>> Thanks!
>>> Scott Lewis
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
