[gdal-dev] OGRGeometry Distance
Mateusz Loskot mateusz at loskot.net
Wed Sep 23 04:55:01 EDT 2009
Christopher Barker wrote:
> Yilmaz Arslanoglu wrote:
>> I wanted to compute the distance between two points,
> you need to be clear by what you mean here: I suspect you mean:
> "The shortest distance between two points following the surface of the
> earth"
> In which case, what you are looking for is referred to as the geodesic
> distance:
> http://www.vterrain.org/Misc/distance.html
> To do this accurately (and you may not need much accuracy!) on an
> ellipsoid requires a fair bit of math. I don't know if it's built in to
> OGR or PROJ at this point, but there are a few libraries out that that
> do it, including Gerald I. Evenden's "geodesic" lib, which can be found
> here:
> http://home.comcast.net/~gevenden56/geodesy/project/
Here is another interesting article on that subject:
http://www.codeguru.com/Cpp/Cpp/algorithms/general/article.php/c5115/
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
