[gdal-dev] Re: gdal_rasterize with a NetCDF file?
Roger André randre at gmail.com
Wed Sep 23 17:36:43 EDT 2009
Hey Scott,
You could extract that layer from the netCDF, burn it with gdal_rasterize as
a geotiff, convert the geoTiff into a GMT grid, and then possibly add that
back into the netCDF (somehow).
Sounds like a pain though.
Roger
On Mon, Sep 21, 2009 at 11:49 AM, Scott Lewis <scott.lewis at nsidc.org> wrote:
> Ah, thanks.  I must have missed that.  Looks like I'll have to find
> another way to accomplish what I'm trying to do then!
> Thanks for your help!
> Scott
> Hermann Peifer wrote:
> > The driver doesn't support updating netCDF files. gdalinfo --formats
> says:
> >  GTiff (rw+): GeoTIFF
> >  netCDF (rw): Network Common Data Format
> > The "+" indicates update support, which is obviously missing for netCDF
> > format.
> > Hermann
> > -------- Original Message  --------
> > Subject: Re:gdal_rasterize with a NetCDF file?
> > From: Scott Lewis <scott.lewis at nsidc.org>
> > To: Date: 21/09/2009 20:37
> >> Evan,
> >> Thanks, that seems to be getting me in the right direction: I'm no
> >> longer getting the segfault error, or "ERROR 5" at all.
> >> However, now it's giving me a different error.  The first line has the:
> >> 0...10...20...30...40...50...60...70...80...90...100 - done.
> >> message, like I would expect from when I do this with GeoTIFF files.
> >> But following that I am getting a whole bunch of this error, repeated
> >> many times:
> >> ERROR 6: WriteBlock() not supported for this dataset.
> >> Doing a search online, I'm getting the impression that this might mean
> >> that gdal_rasterize doesn't support writing to a NetCDF file?  Is this
> >> correct, or does the problem lie elsewhere with my calling of the
> >> utility.
> >> Here's the command line I'm using now:
> >> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize -i -burn 0 -l
> >> "OGRGeoJSON" dummy.json
> >> 'NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement'
> >> Thanks again for the help!
> >> Scott
> >> Even Rouault wrote:
> >>> Selon Scott Lewis <scott.lewis at nsidc.org>:
> >>> Scott,
> >>> Anytime you want to access to a subdataset with a gdal utility, you
> >>> must use the
> >>> value of the relevant SUBDATASET_xxx_NAME metadata item, in that
> >>> instance
> >>> The segmentation fault however wasn't expected, so I commited fixes
> >>> per ticket
> >>> http://trac.osgeo.org/gdal/ticket/3146 to error out more nicely.
> >>> Best regards
> >>>> Hi,
> >>>> I'm still fairly new at using GDAL, but I am having trouble burning a
> >>>> vector image onto a NetCDF file.  I've had success with using
> >>>> gdal_rasterize to burn a vector onto a GeoTIFF file, but when I try to
> >>>> burn the same vector onto a NetCDF file, I get an error.
> >>>> Based on the error, I'm suspecting it's because it doesn't know how to
> >>>> find the right "band" in the NetCDF File (I want the
> >>>> "Albedo_with_1400_Local_Time_of_Measurement" subdataset), but although
> >>>> I've looked at the documentation, I'm not sure how to specify this to
> >>>> gdal_rasterize.
> >>>> Any help would be much appreciated!  Below is the info.
> >>>> Here is the command I am trying to run:
> >>>> "OGRGeoJSON" dummy.json Albedo.nc
> >>>> And the error I get:
> >>>> ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
> >>>> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize: line 9: 26950
> >>>> Segmentation fault      $FWTOOLS_HOME/bin/`basename $TARGET` "$@"
> >>>> Here is the gdalinfo for Albedo.nc:
> >>>> Driver: netCDF/Network Common Data Format
> >>>> Files: Albedo.nc
> >>>> Size is 512, 512
> >>>> Coordinate System is `'
> >>>> Metadata:
> >>>>   NC_GLOBAL#Conventions=CF-1.4
> >>>>   NC_GLOBAL#institution=National Snow & Ice Data Center, Boulder, CO
> >>>>   NC_GLOBAL#title=AVHRR Polar Pathfinder Twice-Daily 5 km EASE-Grid
> >>>> Composites Albedo
> >>>>   NC_GLOBAL#source=See the title and references for this information
> >>>>   NC_GLOBAL#comment=Not set at this time
> >>>>   NC_GLOBAL#references=Documentation available at:
> >>>> http://nsidc.org/data/docs/daac/nsidc0066_avhrr_5km.gd.html
> >>>>   NC_GLOBAL#history=Mon, 21 Sep 2009 09:31:24: File created.
> >>>> Subdatasets:
> SUBDATASET_1_NAME=NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement
> >>>>   SUBDATASET_1_DESC=[1x244x242]
> >>>> Albedo_with_1400_Local_Time_of_Measurement (8-bit integer)
> >>>>   SUBDATASET_2_NAME=NETCDF:"Albedo.nc":latitude
> >>>>   SUBDATASET_2_DESC=[244x242] latitude (64-bit floating-point)
> >>>>   SUBDATASET_3_NAME=NETCDF:"Albedo.nc":longitude
> >>>>   SUBDATASET_3_DESC=[244x242] longitude (64-bit floating-point)
> >>>> Corner Coordinates:
> >>>> Upper Left  (    0.0,    0.0)
> >>>> Lower Left  (    0.0,  512.0)
> >>>> Upper Right (  512.0,    0.0)
> >>>> Lower Right (  512.0,  512.0)
> >>>> Center      (  256.0,  256.0)
> >>>> And for completeness, the dummy.json file (it's basically a triangle):
> >>>>     "type": "FeatureCollection",
> >>>>     "features": [{
> >>>>         "type": "Feature",
> >>>>         "properties": { "BASIN_ID": 1.000000, "AREA_SQKM":
> >>>> 1739.016470 },
> >>>>         "geometry": {
> >>>>             "type": "Polygon",
> >>>>             "coordinates": [ [
> >>>>                 [ -2000000, -2500000 ],
> >>>>                 [ -2500000, -1400000 ],
> >>>>                 [ -1500000, -1400000 ],
> >>>> Thanks!
> >>>> Scott Lewis
> >>>> _______________________________________________
> >>>> gdal-dev mailing list
> >>>> gdal-dev at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090923/0427d32b/attachment-0001.html
