[gdal-dev] GetStatistics and signed 8-bit IMGs and GeoTIFFs
Jason Roberts
jason.roberts at duke.edu
Thu Sep 24 13:50:40 EDT 2009
Even,
Thanks for the response. Please see http://trac.osgeo.org/gdal/ticket/3151.
Best,
Jason
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, September 24, 2009 5:19 AM
To: Jason Roberts
Cc: 'gdal-dev'
Subject: RE: [gdal-dev] GetStatistics and signed 8-bit IMGs and GeoTIFFs
Selon Jason Roberts <jason.roberts at duke.edu>:
Please open a Trac ticket about that. This should be fixable within GDAL
itself
by testing the presence of PIXELTYPE=SIGNEDBYTE and by casting the value to
a
signed byte in that case.
> Ok, here is how a GDAL caller can detect that a file is signed 8-bit:
> >>> band.GetMetadata('IMAGE_STRUCTURE')
> {'PIXELTYPE': 'SIGNEDBYTE'}
> Thanks to Frank W for giving me a clue about this a week ago that I
promptly
> forgot about. Sorry about that.
> So. does anyone know whether band.GetStatistics is supposed to work for
> these signed 8-bit files? If not, I guess I will write a workaround so my
> app will calculate statistics itself for signed 8-bit files.
> Thanks,
> Jason
> From: Jason Roberts [mailto:jason.roberts at duke.edu]
> Sent: Wednesday, September 23, 2009 4:18 PM
> To: 'gdal-dev'
> Someone suggested that I try this with 1.6.2 without saying whether it
might
> be a bug or by design. The behavior is the same with 1.6.2, using binaries
> produced by Tamas Szekeres (thanks Tamas, for providing those on your
> website).
> Back to the original question: is it a bug or by design? How does the GDAL
> caller determine through GDAL that a given file is signed 8-bit or
unsigned
> 8-bit?
> Thanks again,
> Jason
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jason Roberts
> Sent: Wednesday, September 23, 2009 3:11 PM
> To: 'gdal-dev'
> Subject: [gdal-dev] GetStatistics and signed 8-bit IMGs and GeoTIFFs
> Is band.GetStatistics() supposed to work with signed 8-bit integer rasters
> with the HFA or GTiff driver?
> With GDAL 1.6.0, I can successfully create a signed 8-bit raster with the
> HFA or GTiff driver using the PIXELTYPE=SIGNEDBYTE option:
> >>> a = numpy.array([[-128, -1, 0, 1, 127]], dtype='int8')
> >>> a
> array([[-128, -1, 0, 1, 127]], dtype=int8)
> >>> b = numpy.cast['uint8'](a)
> >>> print b
> [[128 255 0 1 127]]
> >>> gdal.UseExceptions()
> >>> driver = gdal.GetDriverByName('HFA')
> >>> dataset = driver.Create(r'C:\Temp\test_int8.img', 5, 1, 1,
> gdal.GDT_Byte, ['PIXELTYPE=SIGNEDBYTE'])
> >>> band = dataset.GetRasterBand(1)
> >>> band.WriteArray(b)
> 0
> >>> del band, dataset, driver
> When I look at that raster with ArcGIS, it shows it is signed 8-bit
integer
> and the five values show up properly. But when I open it with GDAL and
call
> band.GetStatistics(), it looks like the calculation is performed using
> unsigned 8-bit integers:
> >>> dataset = gdal.Open(r'C:\Temp\test_int8.img', gdalconst.GA_ReadOnly)
> >>> band.GetStatistics(False, True)
> [0.0, 255.0, 102.2, 95.199579831005551]
> I am wondering if this is a bug or by design. If by design, is there any
way
> my application can tell through GDAL that it is a signed 8-bit file rather
> than an unsigned 8-bit file?
> Thanks very much for your help,
> Jason
