[gdal-dev] Re: can ogr2ogr split polygons that cross 180 degree longitude
Hermann Peifer peifer at gmx.eu
Wed Sep 30 02:46:22 EDT 2009
Even Rouault wrote:
> Selon Mateusz Loskot <mateusz at loskot.net>:
> The output message doesn't enable us to know where the crash occurs : in GEOS or
> in GDAL. If it was in GDAL, I've tried in r17712 + r17713 to be more robust if
> both intersections are NULL and hopefully avoid it. No warranty, I couldn't
> reproduce your precise issue. If it still persists, attaching a debugger and
> reporting the stack trace when it segfaults might be helpful.
Unfortunately,  r17712 + r17713 did not make a difference. I uploaded my
shapefile to http://tinyurl.com/yjpakj2
Hermann
