[gdal-dev] Gdal2tiles -z not working
Stefano Iacovella stefano.iacovella at gmail.com
Fri Apr 9 03:32:49 EDT 2010
Dear all
I'm trying to use gdal2tiles.py and it seems --zoom parameter is not
working.
The testing configuration is:
Ubuntu 9.10
python 2.6.4
gdal 1.7.1 compiled from source with ECW support
gdal2tiles.py header is
#  $Id: gdal2tiles.py 18194 2009-12-06 20:07:45Z rouault $
If I run gdal2tiles without the --zoom parameter the output image
files are ok and I can preview any level without problem. The syntax
used for the TMS production is
gdal2tiles.py -r cubic -p raster source_dataset.ecw SOURCE_DATASET
If I run with this syntax
gdal2tiles.py -r cubic -p raster --zoom 0 ritaglio.ecw RITAGLIO
the output TMS contains a 0 level with a picture quite different form
those in the previous TMS 0 level. It seems like the image is strtched
up and left.
am I making some error?
Thanks in advance for any hints
Stefano
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100409/0e7b9076/attachment-0001.html
