[gdal-dev] 1.7.1 build error
David Boyd
dboyd at data-tactics.com
Fri Apr 9 11:08:36 EDT 2010
Brian:
Hmmm. Which Linux distro? I just did this under
RedHat 5.4 and did not get that error.
Email me direct and I can send you a tarball of my
build directory.
drdavis wrote:
> I am trying to compile gdal 1.7.1 on 64-bit linux system.
> no problems previously with 1.6.0 nor 1.6.3.
> I get:
> /usr/bin/ld: /usr/local/lib/libjasper.a(jas_stream.o): relocation
> R_X86_64_32S against `a local symbol' can not be used when making a
> shared object; recompile with -fPIC
> /usr/local/lib/libjasper.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> make[1]: *** [libgdal.la] Error 1
> Is there a configure option which takes care of this?
========= mailto:dboyd at data-tactics.com ============
David W. Boyd
Director, Engineering, Research and Development
Data Tactics Corporation
7901 Jones Branch, Suite 240
Mclean, VA 22102
office: +1-703-506-3735, ext 308
fax: +1-703-506-6703
cell: +1-703-402-7908
============== http://www.data-tactics.com/ ============
The information contained in this message may be privileged
and/or confidential and protected from disclosure.
If the reader of this message is not the intended recipient
or an employee or agent responsible for delivering this message
to the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication
is strictly prohibited. If you have received this communication
in error, please notify the sender immediately by replying to
this message and deleting the material from any computer.
