[gdal-dev] Deskewing geo-referenced scanned prints
Even Rouault even.rouault at mines-paris.org
Sun Apr 11 08:24:50 EDT 2010
Zoltan,
With 4 GCPs, by default, gdalwarp uses a 1st-order polynomial
If you provide 6 GCPs or more, it will use a 2nd-order polynomial.
You can also try specifying -tps to use the Thin Plate Spline transformer.
Le Sunday 11 April 2010 13:38:21 Zoltan Szecsei, vous avez écrit :
>  Hi All,
>  Even's advice below (for cropping) was perfect for what I wanted, but now
> I see that the original georeferencing of the scanned images was not that
> great.
>  I have pixel values for the (skew) LatLong corners, but I cant fathom out
> how to use these as GCPs to re-geo-reference the scans. The following
> introduces the GCPs into the image,
>  gdal_translate -gcp 361.125702 529.504089 20.00 -28.25 -gcp 6142.089844
> 530.520996 20.25 -28.25 -gcp 6129.833496 7090.170410 -20.25 -28.50 -gcp
> 359.345825 7085.267090 20.00 -28.50  2820AC_1990_ED2_GEO.TIF
> ../2820ac_gcp.tif
>  but running:
>  gdalwarp -te 20.00 -28.50 20.25 -28.25 2820ac_gcp.tif 2820ac_warp.tif
>  does not give the desired results.
>  What is the correct way to improve the georeferencing of and existing
> GeoTIFF, using GCPs?
>  Thanks & regards,
>  Zoltan
>  Zoltan Szecsei wrote:
>  Hi Even,
>  I think I have spent too much time using older proprietary software. I
> figured the image would have to be deskewed before using "te" option, but
> now that you mention it, it makes sense that gdal would (should) look at
> all the tfw & embedded parameters before it willy-nilly crops for the
> output extents. (So yes, it should "just work")
>  I'll give it a bash on one of the scans.
>  Thanks & regards,
>  Zoltan
>  Even Rouault wrote:
> Zoltan,
> I'd use something like : gdalwarp -te 24.75 -34.25 25.00 -34.00 src.tif
> out.tif
> In your case, you just need to be able to analyze the image name, compute
> xmin, xmax, ymin, ymax, build the gdalwarp line and spawn the new process.
> So I think you could use any programming/scripting language you like. I'd
> personnaly use Python and the GDAL Python bindings (other well supported
> binding languages are Perl, CSharp and Java). The advantage is that you
> wouldn't need to make any assumption on the structure of the image name and
> could get its spatial extent in a more reliable way.
> Le Sunday 11 April 2010 08:49:28 Zoltan Szecsei, vous avez écrit :
> Hi,
> I'm using viewing software that cannot rotate images on the fly (see
> non-zero rotation parameters in TFW below.)
> I have almost 2000 scans in GeoTIFF that I hence need to deskew and also
> want to crop.
> I've been looking at gdalwarp, but can't see an obvious way to
> bash-script deskewing, so please can someone give me a pointer where to
> start/research.
> Thanks in advance,
> Zoltan
> Each image represents a quarter degree square and I can use the image
> name to calculate the Lat Long values of the 4 corners.
> 3424bb is:
> TL:  34.00S 24.75E
> TR:  34.00S 25.00E
> BR:  34.25S 25.00E
> BL:  34.25S 24.75E
> I want to crop the image on these quarter degree boundaries, and deskew it.
> <removed> as msg size exceeded 50k (was 70K)
> The attached jpeg is a much-reduced sample, so you can get the idea of
> what they look like.
> </removed>
> I have the following information at hand:
> ###### ls -la:
>    geograph geograph  5231378 2006-09-13 17:28 3424BB_1999_ED3_GEO.TIF
> ###### Pixel positions of the 4 quarter degree square corners are at:
> TL 1090.489746 1226.423828
> TR 6546.639160 1220.069458
> BR 6546.430176 7770.449219
> BL 1106.605347 7776.899902
> ###### cat 3424BB_1999_ED3_GEO.tfw
>              0.0000459558
>             -0.0000000502
>             -0.0000000963
>             -0.0000381753
>             24.6998662805
>            -33.9529134036
> ###### gdalinfo 3424BB_1999_ED3_GEO.TIF
> Driver: GTiff/GeoTIFF
> Files: 3424BB_1999_ED3_GEO.TIF
> Size is 7796, 10629
> Coordinate System is:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.2572235629972,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0],
>      UNIT["degree",0.0174532925199433],
>      AUTHORITY["EPSG","4326"]]
> GeoTransform =
>    24.6998433507502, 4.595577857784442e-05, -9.634765806162092e-08
>    -33.95289429083027, -5.021067810400542e-08, -3.817529052330018e-05
> Metadata:
>    AREA_OR_POINT=Area
>    TIFFTAG_XRESOLUTION=300
>    TIFFTAG_YRESOLUTION=300
>    TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>    COMPRESSION=LZW
>    INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  24.6998434, -33.9528943) ( 24d41'59.44"E, 33d57'10.42"S)
> Lower Left  (  24.6988193, -34.3586595) ( 24d41'55.75"E, 34d21'31.17"S)
> Upper Right (  25.0581146, -33.9532857) ( 25d 3'29.21"E, 33d57'11.83"S)
> Lower Right (  25.0570905, -34.3590509) ( 25d 3'25.53"E, 34d21'32.58"S)
> Center      (  24.8784669, -34.1559726) ( 24d52'42.48"E, 34d 9'21.50"S)
> Band 1 Block=7796x1 Type=Byte, ColorInterp=Palette
>    Color Table (RGB with 256 entries)
>      0: 106,180,131,255
> etc etc
> Zoltan Szecsei
> Geograph (Pty) Ltd.
> P.O. Box 7, Muizenberg 7950, South Africa.
> 65 Main Road, Muizenberg 7945
> Western Cape, South Africa.
> 34° 6'16.35"S 18°28'5.62"E
> Tel: +27-21-7884897  Mobile: +27-83-6004028
> Fax: +27-86-6115323     www.geograph.co.za
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
