[gdal-dev] Re: ogr2ogr BeTA2007 grid
Tilo Villwock
tilovillwock at gmx.de
Wed Apr 14 04:31:03 EDT 2010
> Try the following: forget about epsg:3396, and instead specify all the
> individual options from epsg:3396. Something like:
> ogr2ogr -s_srs "+proj=tmerc +lat_0=0 +lon_0=9 +k=1 +y_0=0 +ellps=bessel
> +nadgrids=BETA2007.gsb" -t_srs EPSG:25832 target.shp source.shp
I used the parameters instead, but it didn't work either. In fact, I think it doesn't matter since ogr2ogr looks up the same parameters in its EPSG file and converts the whole string to WKT anyway. So the result should be the same.
Any other thoughts?
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
