[gdal-dev] Hi,how to translate many files to a file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Apr 15 09:36:25 EDT 2010
weixj2003ld,
There are two ways. One is to use gdal_merge.py script. Other is to use
gdalbuildvrt to build a VRT and use gdal_translate to convert the VRT to
your desired format. Refer to http://www.gdal.org/gdal_utilities.html for
help.
2010/4/15 weixj2003ld <weixj2003ld at 163.com>
> Hi,
> I have 6 .tif files,and want to get a JPEG file or a tif file.
> How to realize it with command gdal_translate?
> Thk u in advance.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100415/71552895/attachment.html
