[gdal-dev] ColorInterp, Scale, Offset etc VRT to TIFF
Frank Warmerdam
warmerdam at pobox.com
Thu Apr 15 12:47:11 EDT 2010
Andrew Brooks wrote:
> Hello
> My first problem is that when I set ColorInterp in a VRT file it works
> (gdal_info reports the colour interpretation for each band) but when I
> convert to GeoTIFF the information is lost (gdal_info shows Undefined
> for all but the first band). Is that a bug or is tiff not capable of
> representing it?
Andrew,
The TIFF format has a very limited set of photometric interpretation
configurations it supports. Basically it can be:
<Option name="PHOTOMETRIC" type="string-select">
<Value>MINISBLACK</Value>
<Value>MINISWHITE</Value>
<Value>PALETTE</Value>
<Value>RGB</Value>
<Value>CMYK</Value>
<Value>YCBCR</Value>
<Value>CIELAB</Value>
<Value>ICCLAB</Value>
<Value>ITULAB</Value>
</Option>
This means you cannot establish band arrangements other than 1,2,3
to be red, green and blue. Sorry.
> Also I can't set ColorInterp (or Scale, Offset, NoDataValue) in a VRT
> programmatically using the code as shown in the tutorial:
> papszOptions = CSLAddNameValue(papszOptions, "subclass",
> "VRTRawRasterBand");
> papszOptions = CSLAddNameValue(papszOptions, "SourceFilename", "x.dat");
> papszOptions = CSLAddNameValue(papszOptions, "ByteOrder",
> "LSB"); // this WORKS
> papszOptions = CSLAddNameValue(papszOptions, "ColorInterp",
> "Red"); // this is IGNORED
You are correct that many items cannot be set as part of the Create()
or CreateCopy() process on the VRT driver from creation options. But in
most cases you should be able to set these after the fact using the
appropriate methods on the dataset or band.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
