[gdal-dev] GDAL/OGR 1.7.2 Release Candidate
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Wed Apr 21 05:24:29 EDT 2010
Frank Warmerdam wrote:
> Folks,
> Today I updated the news file and prepared a 1.7.2 release candidate.
> The
> NEWS is available at:
> http://svn.osgeo.org/gdal/branches/1.7/gdal/NEWS
> The source files are at:
> http://download.osgeo.org/gdal/gdal-1.7.2RC1.tar.gz
> http://download.osgeo.org/gdal/gdal172RC1.zip
> I regenerated configure with a newer version of autoconf so please
> keep an
> eye on possible negative effects that might have had. Testing is
> encouraged.
> I'll call for a vote to promote it to official release tomorrow I hope.
> Best regards,
I seem to have problems in configures libdap version guess.
On a current CentOS 5.4, x86_64, with some packages taken from EPEL
(http://fedoraproject.org/wiki/EPEL) and the attachen spec file, I come
until the following error message.
g++ -O2 -g -pipe -Wall -fPIC -DPIC -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mtune=generic -Wall -I..
-I/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/port
-I/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/gcore
-I/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/alg
-I/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/ogr
-I/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/ogr/ogrsf_frmts
-DOGR_ENABLED -I/usr/include/ogdi -I/usr/include/netcdf-3
-I/usr/include/netcdf -I/usr/include/hdf -I/usr/include/libgeotiff
-I/usr/include/libdap -DH5_USE_16_API
-Iexternal/include -I/usr/include/netcdf-3 -I/usr/include/cfitsio
-I/usr/include/cfitsio/include -I/usr/lib64/include
-I/usr/lib64/include/libdap -I/usr/lib64/include/dap -DLIBDAP_39 -c
ogrdodsdatasource.cpp -fPIC -DPIC -o ../o/.libs/ogrdodsdatasource.o
ogrdodsdatasource.cpp: In member function 'int
OGRDODSDataSource::Open(const char*)':
ogrdodsdatasource.cpp:197: error: 'class DAS' has no member named
'container'
make[3]: *** [../o/ogrdodsdatasource.lo] Error 1
make[3]: Leaving directory
`/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/ogr/ogrsf_frmts/dods'
make[2]: *** [dods-target] Error 2
make[2]: Leaving directory
`/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory
`/home/peter.hopfgartner/rpmbuild/BUILD/gdal-1.7.2-fedora/ogr'
make: *** [ogr-target] Error 2
error: Bad exit status from
/home/peter.hopfgartner/rpmbuild/tmp/rpm-tmp.81239 (%build)
RPM build errors:
The installed libdap is libdap-3.7.8-1.el5.1, whereas it seems that
./configure guesses 3.9 is installed, see attached config.log, where
LIBDAP_39 gets defined.
Regards,
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
