[gdal-dev] GDAL/OGR 1.7.2RC2 Release Candidate
Jose Gomez-Dans
jgomezdans at gmail.com
Thu Apr 22 14:52:34 EDT 2010
> On Apr 22, 2010, at 11:51 AM, Frank Warmerdam wrote:
>> > Folks,
>> > I have prepared a new 1.7.2 release candidate. In this one I have
>> > run libtoolize --force --copy and then autogen.sh in the hopes of
>> producing
>> > a consistent up-to-date set of configure and libtool stuff. I'd
>> particularly
>> > appreciate the folks who had problems with RC1 trying this out.
I have compiled succesfully 1.7.2 on a RHEL5/x86_64 system (used to need the
--wihtout-libtool option, compiles fine without it now). Additionally, the
HDF include directory is not passed through to the respective Makefiles in
frmts/hdf4. My ./configure command is:
./configure --with-python --with-geos=/usr/bin/geos-config
--with-curl=/usr/bin/curl-config --with-hdf4=/usr/lib64/hdf
--with-sqlite3=yes --with-netcdf=no --with-static-proj4=/usr/lib64/
--with-hdf5=/usr/include/hdf5
Other than that, & when this HDF include is added to the Makefile, the
release seems to work.
Jose
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100422/4e72c8de/attachment.html
