[gdal-dev] RE: Extract WKT actual Data Values starting with rootNode
Zermeno, Robert J CIV NAVAIR, 472100D robert.zermeno at navy.mil
Thu Apr 22 18:29:05 EDT 2010
Frank,
Thanks a lot for the tips.  I have been playing around a bit with the C API and documentation and noticed that the way gdal is loaded in Borland, I cannot use the C++ api of gdal.
My objective is I want to acquire the root node of the WKT tree and for each node, extract the value and its associated data.
Example:
  curRoot = SPHEROID
  value = "WSG 84"
  Data  = integer1, integer2
How can I do this using the C API?  I think that is why you mentioned C++ API has more functionality, like GetRoot().
I cannot build a OGR_SRSNode tree using importFromWKT() or use its Constructor.  Reason it's a C++ API and for some reason in Builder, it gives me an unresolved reference.  So, I know something is wrong with my .lib file.
Last resort is I could use the ExportToPrettyWKT() and manually parse through it (which is WAY easier than then ExportToWKT() )
Thanks for your help,
Robert
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thursday, April 22, 2010 9:29
To: Zermeno, Robert J CIV NAVAIR, 472100D
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] How to extract Well Known Text Coordinate System information (WKT)..., OGR unresolved reference problem
Zermeno, Robert J CIV NAVAIR, 472100D wrote:
> Hi everyone,
> I am enjoying the simplicity of GDAL with integrating with various formats.
> I have two related questions. 1.  How can I simply extract individual
> pieces of WKT?  Meaning, The returned string from GetProjectionRef()
> returns a WKT format coordinate system string describing the
> geographical reference the image pertains to.  I would like to grab each of the components.
Robert,
The GetAttrValue() method on OGRSpatialReference can generally be used to extract specific data items from a coordinate system definition.
For instance:
   const char *pszDatumName = poSRS->GetAttrValue("DATUM");
would search the WKT for the DATUM node, and extract the associated text.
> 2. This is kind of a question: Instead of parsing through the XML
> myself, I thought GDAL already has this functionality.  I have tried to perform:
> OGRSpatialReferenceH poSRS; poSRS->GetPrimeMeridian(), but I receive
> an unresolved reference compile error.  This is odd to me.  I can do
> the GDAL API tutorial section that uses OSRSetUTM(),
> OSRDestroySpatialReference(), OSRExportToWKt(). I have tried to
> include all main ogr.h files: ogr_api.h, ogr_spatialref.h, ogr_core.h, ... But no such luck.
> The platform I am using is Borland C++.  I compiled a dll and lib file
> through MSVC 2008 and used Borland coff2omf.exe to properly convert
> the lib file.
My conclusion would be that this is something peculiar about the way you are building or Borland C++.  It may help to stick to the C rather than C++ API though there are some methods not exposed through C.
Good luck,
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100422/e63facfa/smime.bin
