[gdal-dev] how to use docs?
Randy
randyqiuxy at hotmail.com
Tue Apr 27 03:40:47 EDT 2010
Hi Ivan,
> The GDAL docs that you created with "make docs" is basically a copy of what you have on gdal.org in
> html format generated by Doxygen. You can also run "make man" and "make install-man" if that helps.
Then how do I use this docs file,can I use it in Devhelp or "man" some function in terminal? I find it still doesn't work after
"make man" and "make install-man".
Thanks a lot!
Best regards,
Randy
> Regards,
> Ivan
> Randy wrote:
> > Hi list,
> > This maybe a bad question.
> > I "make docs" and "make install docs" after installing GDAL, but then
> > how should I use this docs file and query functions?
> > I thought Devhelp could help me but nothing appeared on devhelp.
> > Best regards,
> > Randy
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
