[gdal-dev] Reading GRIB2 with GDAL 1.6.3 leeds to Warning: Investigate Template 4.8 bytes 35-41
Eloi Ribeiro eloi.ribeiro at gmail.com
Thu Apr 29 06:35:30 EDT 2010
I keep receiving this warning using GDAL (1.6.3 released 2009/11/19 on
Ubuntu desktop 9.10) whith GRIB2 files:
"Warning: Investigate Template 4.8 bytes 35-41
Segmentation fault"
The strange thing is that it works fine with some GRIB2 data, like this
file[1]
but with some other's, from the same source[2], just won't work at all, like
this one[3].
Do you have any suggestion about this issue? Is there any workaround?
With GRIB 1 version I didn't had any problems.
[1] http://dl.dropbox.com/u/1735137/pgbl01.gdas.T_MIN.2m.grb2
[2] http://dss.ucar.edu/datasets/ds093.2/
[3] http://dl.dropbox.com/u/1735137/ipvlnl.gdas.TMP.SFC.grb2
Thanks for reading till here. By,
Eloi Ribeiro
GIS Analyst
39,45º -4,40º
http://eloiribeiro.wordpress.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100429/99c7d49e/attachment.html
