[gdal-dev] Save to DXF with specific layer name with c#
Colin Wright wrightc at forthvalleygis.co.uk
Mon Aug 2 04:58:38 EDT 2010
Hi Andreas,
Thanks for that - it's comforting to know I wasn't missing something obvious.  I'll have a dig
around in the header.dxf and see what I can do from that end.
I haven't tried them yet, but do you know if there are gotchas with any of the other standard
DXF attributes?  Entities, Text, etc...
Colin
>>> "Andreas Neumann" <a.neumann at carto.net> 30/07/10 13:31 >>>
Hi Colin,
Not sure if creation of layers is yet supported. I think it is only
supported if you created the layers in advance in the header.dxf file.
Frank Warmerdam is now working on a second round of improvements where
automatic layer creation (even if the layers aren't present in header.dxf)
should be supported.
You probably have to wait for a couple weeks for this to appear.
Frank can tell you more about it.
Andreas
On Fri, July 30, 2010 11:21 am, Colin Wright wrote:
> I'm using GDAL/OGR 1.7.2 with the C# bindings to write a tool that will
> export data to various formats.
> When it exports to DXF I want it to use a specific layer name rather than
> using the default dxf layer 0.
> The problem is that even though I'm setting the attribute "Layer" for each
> feature, it is still appearing as layer 0 in the final DXF file.  I've
> checked and the "Layer" attribute does exist, and setting the attribute
> value doesn't throw any errors.  The geometry is getting saved to the DXF
> OK.
> Any ideas?  An extract of my code is below.
> //Loop through input layers writing to output
> lyrInput.ResetReading();
> Feature inFeat = lyrInput.GetNextFeature();
> iError = -1;
> while (inFeat != null)
>                //Try approach of creating new feature
> 	Feature outFeat = new Feature(lyrOutput.GetLayerDefn());
>                 if (outFeat.SetGeometry(inFeat.GetGeometryRef()) ==
> Ogr.OGRERR_NONE)
>                        bFeatOK = true;
>                       //Generic attribs for DXF
>                       if (sOutFormat == "DXF")
>                                   //I've checked and this section is
> getting called
>                                   outFeat.SetField("Layer",
> "MyLayerName");
>                if (bFeatOK)
> 	         iError = lyrOutput.CreateFeature(outFeat);
>                outFeat.Dispose();
> Thanks
> Colin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
