Re: [gdal-dev] EXCEPTION_ACCESS_VIOLATION, when using GDAL Java API
Ivan Lucena
ivan.lucena at pmldnet.com
Wed Aug 4 09:31:54 EDT 2010
I noticed that you are reading and writing from the same GeoRaster, "georaster:georaster/georaster at localhost:1521/orcl,rdt_2,0". Is that what you want?
> -------Original Message-------
> From: <181797177 at qq.com>
> To: gdal-dev <gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] EXCEPTION_ACCESS_VIOLATION, when using GDAL Java API
> Sent: Aug 04 '10 08:23
> Hi,all:
> I use GDAL Java API to write raster data to Oracle Spatial GeoRaster
> Object, and encouter a strange problem:
> # A fatal error has been detected by the Java Runtime Environment:
> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0afa0770, pid=5904,
> tid=5548
> # JRE version: 6.0_15-b03
> # Java VM: Java HotSpot(TM) Client VM (14.1-b02 mixed mode windows-x86 )
> # Problematic frame:
> # C [gdal17.dll+0x190770]
> # An error report file with more information is saved as:
> # D:\workspace\GDALTest\hs_err_pid5904.log
> # If you would like to submit a bug report, please visit:
> # [LINK: http://java.sun.com/webapps/bugreport/crash.jsp]
> # The crash happened outside the Java Virtual Machine in native code.
> This is my Java codes:
> import org.gdal.gdal.gdal;
> import org.gdal.gdalconst.gdalconstConstants;
> import org.gdal.gdal.Band;
> import org.gdal.gdal.Dataset;
> import org.gdal.gdal.Driver;
> import java.nio.ByteBuffer;
> public class GDALTest1 {
> * @param args
> public static void main(String[] args) {
> Dataset Dataset1;
> Dataset Dataset2;
> Band Band1;
> Band Band2;
> gdal.AllRegister();
> // Dataset1 =
> gdal.Open("georaster:georaster/georaster at localhost:1521/orcl,rdt_2,0");
> Dataset1 =
> // Dataset2 =
> gdal.Open("D:/gdal_charles/GeoRasterDemo/private2/georaster_demo/demo_data/data/237898.tif",
> // gdalconstConstants.GA_Update);
> Dataset2 =
> gdal.Open("georaster:georaster/georaster at localhost:1521/orcl,rdt_2,0",
> Band1 = Dataset1.GetRasterBand(1);
> Band2 = Dataset2.GetRasterBand(1);
> Dataset2.SetProjection(Dataset1.GetProjection());
> Dataset2.SetGeoTransform(Dataset1.GetGeoTransform());
> System.out.println("Passing information from input dataset to output
> dataset");
> int XSize = 100;
> ByteBuffer buffer = ByteBuffer.allocateDirect(XSize);
> buffer = Band1.ReadRaster_Direct(0,0,XSize,1);
> Band2.WriteRaster_Direct(0,0,XSize,1,buffer);
> Dataset2.FlushCache();
> System.out.println(buffer.getLong());
> Dataset1.delete();
> Dataset2.delete();
> When executing the sentence "Dataset2.FlushCache();", the above problem
> rises.
> The error report is as following:
> tid=5548
> # See problematic frame for where to report the bug.
> --------------- T H R E A D ---------------
> Current thread (0x00847c00): JavaThread "main" [_thread_in_native,
> id=5548, stack(0x008e0000,0x00930000)]
> siginfo: ExceptionCode=0xc0000005, reading address 0x0000000c
> Registers:
> EAX=0x0d5335d4, EBX=0x00200000, ECX=0x00000000, EDX=0x0b678908
> ESP=0x0092fb78, EBP=0x0e1d0020, ESI=0x0b676b38, EDI=0x00000000
> EIP=0x0afa0770, EFLAGS=0x00010217
> Top of Stack: (sp=0x0092fb78)
> 0x0092fb78: 0aedb0f8 0d5335d4 0e1d0020 00200000
> 0x0092fb88: 00000000 0092fc68 00000000 0b679810
> 0x0092fb98: 0aed6b97 00000000 00000000 00000000
> 0x0092fba8: 00000000 0dfc0020 0b6788d0 00000000
> 0x0092fbb8: 0b67cf38 0ae40cf3 00000000 00000000
> 0x0092fbc8: 0dfc0020 00000000 0ae3cb70 00000000
> 0x0092fbd8: 0b679810 00000000 0ae3e9e7 00000000
> 0x0092fbe8: 00000000 00000000 06c10db0 0b67c9e8
> Instructions: (pc=0x0afa0770)
> 0x0afa0760: c4 08 f7 d8 1b c0 f7 d0 23 44 24 0c c2 0c 00 cc
> 0x0afa0770: 8b 41 0c 8b 54 24 08 56 8b 74 24 10 50 6a 01 6a
> Stack: [0x008e0000,0x00930000], sp=0x0092fb78, free space=318k
> Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
> code)
> Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
> j org.gdal.gdal.gdalJNI.Dataset_FlushCache(JLorg/gdal/gdal/Dataset;)V+0
> j org.gdal.gdal.Dataset.FlushCache()V+5
> j
> oracle.spatial.georaster.gdaltest.GDALTest1.main([Ljava/lang/String;)V+93
> v ~StubRoutines::call_stub
> --------------- P R O C E S S ---------------
> Java Threads: ( => current thread )
> 0x0ab17800 JavaThread "Low Memory Detector" daemon [_thread_blocked,
> id=4276, stack(0x0ad60000,0x0adb0000)]
> 0x0ab11400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1824,
> stack(0x0ad10000,0x0ad60000)]
> 0x0ab0c400 JavaThread "Attach Listener" daemon [_thread_blocked, id=1452,
> stack(0x0acc0000,0x0ad10000)]
> 0x0ab23c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
> id=2400, stack(0x0ac70000,0x0acc0000)]
> 0x0aaf5800 JavaThread "Finalizer" daemon [_thread_blocked, id=4672,
> stack(0x0ac20000,0x0ac70000)]
> 0x0aaf4400 JavaThread "Reference Handler" daemon [_thread_blocked,
> id=4668, stack(0x0abd0000,0x0ac20000)]
> =>0x00847c00 JavaThread "main" [_thread_in_native, id=5548,
> Other Threads:
> 0x0aaf1400 VMThread [stack: 0x0ab80000,0x0abd0000] [id=4820]
> 0x0ab21c00 WatcherThread [stack: 0x0adb0000,0x0ae00000] [id=1532]
> VM state:not at safepoint (normal execution)
> VM Mutex/Monitor currently owned by a thread: None
> Heap
> def new generation total 960K, used 596K [0x029e0000, 0x02ae0000,
> 0x02ec0000)
> eden space 896K, 66% used [0x029e0000, 0x02a75210, 0x02ac0000)
> from space 64K, 0% used [0x02ac0000, 0x02ac0000, 0x02ad0000)
> to space 64K, 0% used [0x02ad0000, 0x02ad0000, 0x02ae0000)
> tenured generation total 4096K, used 0K [0x02ec0000, 0x032c0000,
> 0x069e0000)
> the space 4096K, 0% used [0x02ec0000, 0x02ec0000, 0x02ec0200,
> 0x032c0000)
> compacting perm gen total 12288K, used 2410K [0x069e0000, 0x075e0000,
> 0x0a9e0000)
> the space 12288K, 19% used [0x069e0000, 0x06c3aa68, 0x06c3ac00,
> 0x075e0000)
> No shared spaces configured.
> Dynamic libraries:
> 0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
> 0x7c920000 - 0x7c9b6000 C:\WINDOWS\system32\ntdll.dll
> 0x7c800000 - 0x7c91e000 C:\WINDOWS\system32\kernel32.dll
> 0x77da0000 - 0x77e49000 C:\WINDOWS\system32\ADVAPI32.dll
> 0x77e50000 - 0x77ee2000 C:\WINDOWS\system32\RPCRT4.dll
> 0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
> 0x77d10000 - 0x77da0000 C:\WINDOWS\system32\USER32.dll
> 0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
> 0x76300000 - 0x7631d000 C:\WINDOWS\system32\IMM32.DLL
> 0x62c20000 - 0x62c29000 C:\WINDOWS\system32\LPK.DLL
> 0x73fa0000 - 0x7400b000 C:\WINDOWS\system32\USP10.dll
> 0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
> 0x6d800000 - 0x6da8b000 C:\Program Files\Java\jre6\bin\client\jvm.dll
> 0x76b10000 - 0x76b3a000 C:\WINDOWS\system32\WINMM.dll
> 0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
> 0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
> 0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
> 0x76bc0000 - 0x76bcb000 C:\WINDOWS\system32\PSAPI.DLL
> 0x6d7f0000 - 0x6d7ff000 C:\Pr
