[gdal-dev] c# binding and .net4
Tamas Szekeres
szekerest at gmail.com
Thu Aug 5 08:05:08 EDT 2010
I think you may refer to the issue reported in
http://trac.osgeo.org/gdal/ticket/3560
I've now updated the GDAL csharp bindings to include that fix which already
exists in SWIG 2.0.
Upgrading the bindings to support SWIG 2.0 would be quite complicated due to
several backward incompatible changes introduced from versions to versions.
In addition we have a number of local fixes to rework the original behaviour
of SWIG causing further memory issues with the .NET garbage collection.
These problems hasn't yet been included in the SWIG codebase (and I'm not
sure it will ever be added) make that impossible to use SWIG as it stands in
the GDAL C# bindings.
These changes will be included in the next daily build available to download
at: http://vbkto.dyndns.org/sdk/
Best regards,
Tamas
2010/8/5 Livneh Yehiyam <yehil at rafael.co.il>
> Hi
> As you probably aware GDAL currently fails to run when used in a .net4
> client.
> I know that there is a newer version of swig (2.0) that fixes that.
> Are there any plans to move to the new swig version?
> Thanks
> Yehiyam
> * This message (including any attachments) issued by RAFAEL- ADVANCED
> DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential
> information intended for a specific individual and purpose, may constitute
> information that is privileged or confidential or otherwise protected from
> disclosure. If you are not the intended recipient, you should contact us
> immediately and thereafter delete this message from your system. You are
> hereby notified that any disclosure, copying, dissemination, distribution or
> forwarding of this message, or the taking of any action based on it, is
> strictly prohibited. If you have received this e-mail in error, please
> notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely
> delete or destroy any and all electronic or other copies of the original
> message and any attachments thereof. *
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100805/ea1faf82/attachment.html
