[gdal-dev] ogr2ogr clipping shapefile
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 6 03:50:30 EDT 2010
Giacomo,
The ogr2ogr utility can do that. Use the clipping options.
http://gdal.org/ogr2ogr.html
On Fri, Aug 6, 2010 at 1:00 PM, Giacomo Piva <piva at meeo.it> wrote:
> Hi all,
> I need to cut a shapefile usins as bounding box another shapefile.
> Does someone can explain me how to do that with ogr2ogr?
> Thank you very much
> Giacomo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100806/718c9cc9/attachment.html
