[gdal-dev] split netCDF
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Aug 6 07:42:35 EDT 2010
Martin,
Use the gdal_translate utility (http://www.gdal.org/gdal_translate.html)
with the -b option. You will have to run the command once for each band. A
simple shell script should do it.
On Fri, Aug 6, 2010 at 4:26 PM, Matin80 <martin at bier-mail.de> wrote:
> Hi everyone,
> I have a netCDF-file containing over 300 bands.
> is it possible to split up the file and get the same number of GeoTiffs
> with
> GDAL in a single command line? All i found to this topic ended in merging
> the bands to a single output file...
> kind regards,
> Martin
> http://osgeo-org.1803224.n2.nabble.com/split-netCDF-tp5380091p5380091.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100806/2cf386cb/attachment.html
