[gdal-dev] Motion: Adopt RFC 29: OGR Set Ignored Fields
Tamas Szekeres
szekerest at gmail.com
Sat Aug 7 11:08:39 EDT 2010
2010/8/7 Frank Warmerdam <warmerdam at pobox.com>
> ogr2ogr has a -select switch to identify desired fields
> to be copied to the output. I imagine ogr2ogr could
> benefit from ignoring all the undesired attributes using
> this new api.
Frank,
There are some other tools like ogrinfo, gdal_grid also support the sql
option. I mean it would be desirable to provide unique implementation for
each.
> Currently there is no logic in the OGR SQL engine to
> ignore fields not needed in the result but I can see that
> adding this would be desirable. It would require some
> work to walk all the expression trees (for the WHERE
> and each of the column expressions) to identify the
> fields that are used in the primary and joined tables. I
> would potentially be willing to implement this optimization.
In this case I would support to postpone the implementation in ogr2ogr to
avoid parallel approaches to coexist in ogr2ogr and the common code.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100807/a593bc48/attachment.html
