[gdal-dev] Python Bindings
William Kyngesburye woklist at kyngchaos.com
Sat Aug 7 11:20:57 EDT 2010
I couldn't think of anything at first, but now I wonder if it's an arch problem.  Usually errors say if there is a missing architecture in the binaries.
On OS X Snow Leopard python normally runs 64bit, unless you have one of the first Intel Macs with Core solo/duo processors.  You are compiling GDAL 32bit.  And without some other env settings Python compiles modules 32+64bit, but you won't see compile errors due to the way it compiles.
Try removing the arch flags so it compiles 64bit.  Heck, no need to explicitly set CC, CXX, ... at all.
On Jul 26, 2010, at 5:35 PM, Jeff Hamann wrote:
> I've built GDAL/OGR (1.7.2) with the following ./configure options
> $ ./configure \
> CC="gcc -arch i386" \
> CXX="g++ -arch i386" \
> OBJC="gcc -arch i386" \
> F77="gfortran -arch i386" \
> FC="gfortran -arch i386" \
>  --with-pg=/usr/local/pgsql/bin/pg_config \
>  --without-macosx-framework \
>  --without-sqlite3 \
>  --with-python
> Even though I run on a mac, I really don't want to build with the framework.
> When I attempt to run a simple Python script:
> #! /usr/bin/env python
> from osgeo import gdal
> I get the following:
> Jeff-Hamanns-MacBook-Pro:scripts hamannj$ python pytest.py
> Traceback (most recent call last):
>  File "pytest.py", line 2, in <module>
>  File "/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/__init__.py", line 21, in <module>
>    _gdal = swig_import_helper()
>  File "/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/__init__.py", line 17, in swig_import_helper
>    _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: dlopen(/Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so, 2): Symbol not found: _CPLDefaultErrorHandler
>  Referenced from: /Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so
>  Expected in: flat namespace
> in /Library/Python/2.6/site-packages/GDAL-1.7.2-py2.6-macosx-10.6-universal.egg/osgeo/_gdal.so
> I know *nothing* about python.
> There are a bunch of these statements:
> from osgeo import osr
> import osgeo.gdalconst as gdalc
> from optparse import OptionParser, OptionGroup
> import binascii
> import glob
> import math
> import numpy
> import os
> import sys
> in the gdal2wktraster.py file that I eventually want to run, but I don't know enough about python to diagnose, debug, and correct these problems.
> Is this a python binding problem with gdal/ogr?
> When I ./configured gdal/ogr: I got the following results:
> GDAL is now configured for i386-apple-darwin10.4.0
>  Installation directory:    /usr/local
>  C compiler:                gcc -arch i386  -g -O2
>  C++ compiler:              g++ -arch i386  -g -O2
>  LIBTOOL support:           yes
>  LIBZ support:              external
>  GRASS support:             no
>  CFITSIO support:           no
>  PCRaster support:          internal
>  NetCDF support:            yes
>  LIBPNG support:            internal
>  LIBTIFF support:           internal (BigTIFF=yes)
>  LIBGEOTIFF support:        internal
>  LIBJPEG support:           internal
>  8/12 bit JPEG TIFF:        yes
>  LIBGIF support:            internal
>  OGDI support:              no
>  HDF4 support:              no
>  HDF5 support:              no
>  Kakadu support:            no
>  JasPer support:            no
>  ECW support:               no
>  MrSID support:             no
>  MSG support:               no
>  GRIB support:              yes
>  EPSILON support:           no
>  cURL support (wms/wcs/...):yes
>  PostgreSQL support:        yes
>  MySQL support:             no
>  Ingres support:            no
>  Xerces-C support:          no
>  NAS support:               no
>  Expat support:             yes
>  ODBC support:              no
>  PGeo support:              no
>  PCIDSK support:            internal
>  OCI support:               no
>  GEORASTER support:         no
>  SDE support:               no
>  DODS support:              no
>  SQLite support:            no
>  SpatiaLite support:        no
>  DWGdirect support          no
>  INFORMIX DataBlade support:no
>  GEOS support:              yes
>  VFK support:               yes
>  Mac OS X Framework :       no
>  SWIG Bindings:          python
>  Statically link PROJ.4:    no
>  enable OGR building:       yes
>  enable pthread support:    no
>  hide internal symbols:     no
> Jeff-Hamanns-MacBook-Pro:gdal-1.7.2 hamannj$
> Jeff Hamann
> jeff.d.hamann at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
