[gdal-dev] vsizip & vsigzip on Win
Joaquim Luis jluis at ualg.pt
Sun Aug 8 20:06:49 EDT 2010
I'm trying to access ziped files on Windows using the /vsizip but it
fails most of times
According to docs, this should work no?
gdalinfo c:/vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt
but it doesn't. I get
ERROR 4: `c:/vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt' does not
exist in the file system,
and is not recognised as a supported dataset name.
However, I'm able to make it work by using the unix pathname syntax
gdalinfo /vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt
but even this only works when I run the command from the root dir, that
is from C:\
If run it from any another location I get the same error message.
Joaquim Luis
