[gdal-dev] Re: How to retain double precision in GDAL?
Ole Nielsen Ole.Nielsen at aifdr.org
Sun Aug 8 22:40:33 EDT 2010
Thanks for fixing the precision loss so quickly.
"you now can set the configuration option AAIGRID_DATATYPE to Float64 to
force Float64 being used to avoid the loss of precision."
I am not exactly sure whether this option relates to the gdal_translate
command line utility or the Python binding (ReadAsArray) - or both.
Could you perhaps post the updated script that produced the double precision
values correctly?
Thanks
Ole Nielsen
Ole Nielsen
Australia - Indonesia Facility for Disaster Reduction
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-How-to-retain-double-precision-in-GDAL-tp5379507p5387617.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
