[gdal-dev] unable to append data to orale spatial
Peter J Halls
P.Halls at york.ac.uk
Wed Aug 11 02:25:44 EDT 2010
Imran,
in the documentation for the OCI Driver it says clearly that the spatial
extent and SDO_GEOM_METADATA entries are not updated when using append mode and
that it is up to the caller to manage these.
It is actually quite easy to code for this, but does require an SQLExecute
to handle SDO_GEOM_METADATA. I simply generate this on the fly, along with the
SQL to update the spatial index.
Best wishes,
Peter
Imran Rajjad wrote:
> Hi list,
> I inserted a shape file in oracle 11g, now I have another shape file
> with exactly same attributes, I`m using the -append option but it
> seems the new shapefile wont get appended to the table, there seems to
> be some problem related to the spatial index because data in both
> shape files does not come under same spatial extent, is there anyway
> to tell gdal not to create spatial index when data is being inserted
> and when all the data has been inserted we create the spatial index
> manualy?
> regards,
> Imran
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806 Fax: 01904 433740
Snail mail: IT Services, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
