[gdal-dev] GDAL equivalent of ArcGIS's focal statistics,
raster interpolati
Hannes Reuter
gisxperts at web.de
Wed Aug 11 06:42:11 EDT 2010
Dear Mxxxx,
I programmed some of my recent zonalstats/DOCELL/IFTHENELSE (AG slang)
work in numpy/scipys functionality for terrain analysis.
Have a look there, and in combination with gdal its rather
straightforward. The only problem you might run into is that at one
stage you need to implement tiling as your memory might not be able to
fit your dem into it.
Cheers hannes
