Re: [gdal-dev] ArcGIS 10
Ivan Lucena
ivan.lucena at pmldnet.com
Thu Aug 12 09:10:22 EDT 2010
Hannes,
I just did it!
Ingredients:
- ArcGIS 10
- Visual Studio.NET 2003
- SWIG (swigwin-1.3.31) (or newer, maybe)
- GDAL source code (doesn't need to be the same version that Arc uses)
How to prepare:
- Build GDAL (see gdal.org)
- Set the variables SWIG and PYDIR on nmake.opt
- Set the path for the ArcGIS Python folder:
..\gdal> set PATH=E:\Python26\ArcGIS10.0;%PATH%
- Set the path for SWIG (obviously):
..\gdal> set PATH=<your swig folder>;%PATH%
- Build the GDAL Python wrapper:
..\gdal\swig> nmake -f makefile.vc python
- Generate the GDAL Python installer:
..\gdal\swig> cd python
..\gdal\swig\python> python setup.py bdist_wininst
- Run the installer:
..\gdal\swig\python> cd dist
..\gdal\swig\python\dist> GDAL-1.7.0.win32-py2.6.exe
- Open ArcMap again and click on the "Python window" icon
or select "Geoprocessing/python" from the ArcMap menu
- To launch GDAL just type the usual:
>>> from osgeo import GDAL
>>> from osgeo import OGR
- VOILA
Alternative:
if you just download and run the GDAL-Python installer it probably is not going to find the ArcGIS's Python installation on the register. So you can ask someone to prepare one for you like I did.
Attention:
Again, you are going to be running two different versions of GDAL in ArcMap's Python command line!
Regards,
Ivan
> -------Original Message-------
> From: Hannes Reuter <gisxperts at web.de>
> To: discoursemap at live.com, gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] ArcGIS 10
> Sent: Aug 11 '10 12:19
> YES, numpy / gdal is under my Python 2.6/AG10site packages,
> on the other hand, installing python, numpy, gdal, scipy is rather
> straightforward and should be done in less than 10 minutes.. ;-)
> The only problem I was running in -> Vista and Win7 maschines need the
> newest version of gdal (larger than 1.6) to execute GDAL's readasarray,
> while ogr is fine.. .otherwise they just die, while all is fine on XP
> and linux. see
> http://osgeo-org.1803224.n2.nabble.com/Gdal-Python-Win7-crash-with-ReadAsArray-td4398401.html
> hannes
> hth
> > I hear the new ArcGIS10 has GDAL and NumPy built into the geoprocessor. If this is true, does that mean that users will not have to install the various Python library bindings GDAL, numpy, etc. after a full Arc10 install?
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100811/5b8eebc1/attachment-0001.html
> gdal-dev mailing list
