[gdal-dev] gdal.ReprojectImage error with gdal 1.7.1
Even Rouault
even.rouault at mines-paris.org
Thu Aug 12 10:45:10 EDT 2010
Matthieu,
I'm not sure 100% whether this is the cause of the error you get (in my memory,
the test suite passed correctly for any recently released version), but I'd
suggest you upgrading to 1.7.2 that fixes
http://trac.osgeo.org/gdal/ticket/3458, which was a serious regression present
in 1.7.0 and 1.7.1 that could have caused what you observe.
Best regards,
Even
Selon Matthieu Rigal <rigal at rapideye.de>:
> Hi guys,
> I just upgraded my gdal version to 1.7.1 and I had a bad surprise figuring
> some of my scripts were not working anymore and I could quickly figure out
> where it came from : gdal.ReprojectImage is not working as it should...
> I downloaded the reproject.py script from the autotest to see what is
> happening with the default tests you are also conducting.
> Results:
> reproject_1 success
> reproject_2 4143 cs, failed
> When I look at the images, the byte.tif is OK, the byte_4326 has a black
> border on its right. And the image I was reprojecting from 300*300 to
> 5000*5000 was fully black !!!
> Any one has an idea where it could come from ?
> It looks a bit like bad memory management... I have python 2.6.2 here
> I searched on the net and on the list, I could not find any similar issue...
> Regards,
> Matthieu
> RapidEye AG
> Molkenmarkt 30
> 14776 Brandenburg an der Havel
> Germany
> Follow us on Twitter! www.twitter.com/rapideye_ag
> Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> Management Board/Vorstand: Wolfgang G. Biedermann
> Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
> Juergen Breitkopf
> Commercial Register/Handelsregister Potsdam HRB 17 796
> Tax Number/Steuernummer: 048/100/00053
> VAT-Ident-Number/Ust.-ID: DE 199331235
> DIN EN ISO 9001 certified
> Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> The information in this e-mail is intended for the named recipients
> only. It may contain privileged and confidential information. If you
> have received this communication in error, any use, copying or
> dissemination of its contents is strictly prohibited. Please erase all
> copies of the message along with any included attachments and notify
> RapidEye AG or the sender immediately by telephone at the number
> indicated on this page.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
