[gdal-dev] PyPI GDAL package has development default,
does not easy_install
Luke Tucker
ltucker at openplans.org
Fri Aug 13 20:04:38 EDT 2010
I noticed the releases of the python GDAL bindings uploaded to PyPI have a
strange default setting. Namely, the line in setup.cfg that sets:
gdal-config="../../apps/gdal-config"
See:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/setup.cfg?annotate=blame&rev=15445
This appears to be reasonable in a development context when building
everything from scratch, but when just installing the python package from a
random location, it seems unlikely at best ;) Removing the line from
setup.cfg when uploading PyPI packages would allow setup.py to guess that
gdal-config is in the user's path (more likely)
The default results in the following behavior:
GDAL-1.7.1$ python ./setup.py install
running install
running bdist_egg
running egg_info
writing GDAL.egg-info/PKG-INFO
writing top-level names to GDAL.egg-info/top_level.txt
writing dependency_links to GDAL.egg-info/dependency_links.txt
Could not run gdal-config!!!!
[... chaos ensues]
A similar error occurs running easy_install GDAL. After removing the line,
works fine for me.
I created a ticket about this a while ago, but it doesn't look like anyone
has touched it:
http://trac.osgeo.org/gdal/ticket/3375
- Luke
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100813/50c59616/attachment.html
