[gdal-dev] ArcGIS 10 and GIO driver
Gregory, Matthew matt.gregory at oregonstate.edu
Wed Aug 18 14:37:30 EDT 2010
Hi all,
I know this is likely not to get a lot of attention, given that the GIO driver is currently unsupported and I'm guessing the issue is on the ArcGIS side.  But I'll give it a try anyway ...
I build GDAL from SVN trunk and had included the (old) GIO driver for ArcInfo output grid support.  At ArcInfo 9.x, this worked well (albeit without projection support).  However, now that I've installed ArcInfo 10, I'm getting license errors on simple utilities like gdal_translate, e.g.
  d:\matt>gdal_translate -of GIO dem.tif test_dem
  Input file size is 100, 100
  Warning 1: GIO driver only supports Float32, and Int32 datasets, not
  Int16 as requested for test_dem.  Treating as Int32.
  0Unauthorized license
The DLL aigridio.dll is still at the expected location (C:\ArcGIS\arcexe10x\bin) which is in my PATH and I haven't had any license issues otherwise (through Workstation, ArcMap, etc.).  Has anybody else run into this (unlikely) scenario?
Thanks for any help,
matt
