[gdal-dev] OGR OVF has no identified FID column
Brent Fraser
bfraser at geoanalytic.com
Thu Aug 19 17:21:12 EDT 2010
I think it's faster since it doesn't have to enumerate all the tables,views, etc.
so how do you get for attributes names when you do a
ogrinfo test.ovf PointData --debug on
Brent
David Lowther wrote:
> Still doesn't see the FID but is way faster!
> <OGRVRTDataSource>
> <OGRVRTLayer name="PointData">
> <SrcDataSource>ODBC:un/pw at CLO,PointData</SrcDataSource>
> <GeometryField encoding="WKB" field="Feature"/>
> <FID>PKey</FID>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> ogrinfo test.ovf --debug on
> ERROR 4: Update access not supported for VRT datasources.
> OGR_ODBC: EstablishSession(DSN:"CLO", userid:"un", password:"pw")
> ODBC: SQLConnect(CLO)
> OGR_ODBC: Table PointData has no identified FID column.
> OGR: OGROpen(ODBC:un/pw at CLO,PointData/02799B88) succeeded as ODBC.
> OGR: OGROpen(test.ovf/010270B8) succeeded as VRT.
> Had to open data source read-only.
> INFO: Open of `test.ovf'
> using driver `VRT' successful.
> OGR: GetLayerCount() = 1
> 1: PointData
> ODBC: SQLDisconnect()
> Does the datatype of the FID column matter? I have it as an int, does it
> need to be guid?
> David Lowther
> Coordinate Solutions, Inc.
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, August 19, 2010 3:49 PM
> To: David Lowther
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] OGR OVF has no identified FID column
> Yeah I saw that after I sent the message. Take out the <SrcSQL>, it's
> really
> only useful if want to do "special" things, and it can kill spatial indexing
> on
> ODBC datasources. Does this work any better:
> <OGRVRTDataSource>
> <OGRVRTLayer name="UserPoint">
> <FID>PKey</FID>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Brent
>> Brent,
>> Thanks for the reply. On initial read I thought you had found my issue -
>> that I was trying so many things I finally messed it all up. But on closer
>> inspection I am aliasing the PKey column to FID in the SrcSQL (select PKey
>> as FID, Feature from PointData).
>> When <FID>FID</FID> ogrinfo returns:
>> ODBC: ExecuteSQL(select PKey as FID, Feature from PointData) called.
>> OGR_ODBC: Table SELECT has no identified FID column.
>> OGR: OGROpen(test.ovf/00ED7090) succeeded as VRT.
>> 1: UserPoint
>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02719D10) dereferenced and now
>> destroying.
>> When <FID>PKEY</FID> ogrinfo returns:
>> ERROR 1: Unable to identify FID field 'PKey'.
>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02C39D18) dereferenced and now
>> destroying.
>> FAILURE:
>> Unable to open datasource `test.ovf' with the following drivers.
>> -> ESRI Shapefile
>> David Lowther
>> Sent: Thursday, August 19, 2010 3:15 PM
>> To: David Lowther
>> How about using:
>> <FID>PKey</FID>
>> but that doesn't explain why it takes a long time...
>> Best Regards,
>> Brent Fraser
>>> List,
>>> I have an OVF layer defined as follows:
>>> <OGRVRTDataSource>
>>> <SrcDataSource>ODBC:un/pw at CLO</SrcDataSource>
>>> <SrcSQL>select PKey as FID, Feature from PointData</SrcSQL>
>>> <FID>FID</FID>
>>> </OGRVRTLayer>
>>> </OGRVRTDataSource>
>>> The ODBC connection is to a SQL Express 2008 database. The PointData
> table
>>> is defined as follows:
>>> CREATE TABLE [dbo].[PointData](
>>> [PKey] [int] IDENTITY(1,1) NOT NULL,
>>> [Feature] [geometry] NULL,
>>> CONSTRAINT [PK_PointData] PRIMARY KEY CLUSTERED
>>> [PKey] ASC
>>> )WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY =
>>> OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
>>> ) ON [PRIMARY]
>>> This query
>>> select *, Feature.STAsText() from pointdata
>>> yields
>>> 1 0x00000000010C0000000000C062400000000000C06240 POINT (150 150)
>>> "ogrinfo test.ovf --debug on" runs for a very long time returning many
>> lines
>>> of this sort of stuff:
>>> ODBC: CatalogNameL: (null)
>>> Schema name: (null)
>>> OGR_ODBC: Table UserMapData has no identified FID column.
>>> OGR_ODBC: Table CHECK_CONSTRAINTS has no identified FID column.
>>> before finally saying:
>>> OGR: OGROpen(ODBC:un/pw at CLO/02C79D10) succeeded as ODBC.
>>> OGR: OGROpen(test.ovf/00E17090) succeeded as VRT.
>>> 1: UserPoint
>>> OGR: ReleaseDataSource(ODBC:un/pw at CLO/02C79D10) dereferenced and now
>>> destroying.
>>> GDAL version is 1.6.0.
>>> I have tried using no FID tag and using SrcLayer instead of SrcSQL.
>> Anybody
>>> know what I could do to make it see the FID? I'm guessing it would be a
>> lot
>>> faster if it didn't check every table in the database for an FID...
>>> Thanks in advance for your assistance,
>>> Dave Lowther
